Hi there
I have removed a wall hung book case. Below this is a line plastered wall. Someone has previously put lining paper directly on to this wall and it has bonded directly to the line top coat. Can I patch this hole or will I need to remove all the lining paper and then reskim the whole wall.
If patching should I use lime or can I get away with gypsum plaster?
Any ideas greatly appreciated!!
