Little patch
John j
Mono Don
Few more todo as scaffold had to be fixed to wall. See how it drys .
Might have to sort that crack if it gets pulled. 3 floors up so good point to practice
Orange dolphin tape, scratched most off before I took the tape off worked the edges in. Not seen it since, it won’t be the same colour, was done about 8 month after.
Out of curiosity is there anything to stain/bleach render so can lighten/darken it on patches?
No one likes a show off.
What tape did you use and did you take tape of before you scratched.
What did it dry like
I use masking tape @25mm if I can get it to stick as I find its thin-ness goes into every nook and cranny and right up to the edge Then blue dolphin over that. Scratch back to the blue dolphin leaving the thickness of the tape proud then remove the tape and carefully scratch the little bit proud back to flush being careful not to touch the existing.
