Plasterers1StopShop
Package offer on the EZEK4 and EZE Genset - Rendering Machine
Full setup: £7000.00 + VAT with £150 worth of free tools of your choice!
EZE K4 -
The EZE K4 is the latest machine avalaible to PFT Central within the EZE Range. The EZE K4 machine is manufacturered within the EU but the specification has been deisgned to suit the UK market. With the main parts of the machine coming from reputable manufacturers the EZE K4 has been designed to perform and has also been built to last. Meaning the machine will compete on an even level with its competing brands
Affordable - Cost Effective - Reliable & more importantly its a serious performer
Specification:
Length: 900mm
Width: 720mm
Height: 1500mm
Weight: 220kg
Basket Capacity: 135kg
Yeild: 6-60l
Max Pumping Pressure: 30 Bar
Conveying Distance: Upto 50m
Pump Motor: 5,5KW/400 RPM
Star Wheel Motor: 0.75/ 28RPM
Water Pump: 400V
Compressor: LK-250 - 250l/min
Power: 400v 32AMP 3 Phase
Conveying Capacity: 20l/min
Standard Equipment:
D,6-3 P1 Rotor and Stator - 20l/min Output - Top Motor and Star Wheel Motor, Air Compressor, 25mm 20m Rondo Hose and Air Line, 35mm - 25mm Reducer, Water Pump (fitted), Cleaning Tool, Tool Kit, Cleaning Coupling, 20m Water Hose, Water Barrel and Rotor and Stator Removal Tool & Electric Cable 25m
EZE Genset
An exciting powerful new Generator designed and manufactured at our depot in Cheltenham
Specification:
Kohler Engine: 20 HP - Petrol Engine
Output: 15KvA - 415v 32Amp Socket - 240v 16AmP Socket
Weight: 145kg
Length: 970cm
Width: 750cm
Height: 780cm
The EZE Genset comes as standard with a 2 year warranty on the engine and a 1 year warranty on the Alternator
All Machines will come with training free of charge at our depot in Cheltenham - For more information on other machine deals, please do not hesitate to ask.
Ryan
EZE K4 -
Specification:
Length: 900mm
Width: 720mm
Height: 1500mm
Weight: 220kg
Yeild: 6-60l
Water Pump: 400V
Standard Equipment:
EZE Genset
Specification:
Weight: 145kg
Length: 970cm
Width: 750cm
Height: 780cm
Ryan
