bag an a hafNice one arti looks wicked
2 bags do it ?
Minster in Walker. Before I went there I asked loads of places doves. MKM. Jewsons and the all replied "Erm" they can order it in for you. When you ask how much you will get "Erm" b&q do it if you have one up your way?Where did you get it from @Arti cos when i asked about it in our merchants up here they thought i was taking the pish
£56 + vat from MinsterHow much a bag did you pay Arti?
Cheapest price by a long way that ive heard of.£56 + vat from Minster
Sent from my D2303 using Tapatalk
If you go tight at the top of the wall which you probably won't use you should get away with it.Does it really only cover 5m2? I'm thinking on doing a wall in my house that's about 6.5m2
5mmIs it a 2mm finish.
Recommended 3mm ok to 7mm max I go for 5/6mm it's better with the weaker magneticsIs it a 2mm finish.
Yes..3-3.5hours if two coated I findSo 5mm I take it it hangs for a while so
If am supplying it. It will be one coat so.Yes..3-3.5hours if two coated I find
I never one coat with this clemo others might but to important to me that it works for all the money involved if it don't work CUs it's to thin your stuffedIf am supplying it. It will be one coat so.
You would be fine with it using as same as normal plaster all I am saying is if you did same as arti has above first coat on both walls and half bag laid in is spot on.charge for 2 bags keep the other half bag for next job and then charge next customer for 2 bags up you would only use one plus the half u have left from other job.then the materials price is not an issue for the spreadI don't know anything about it. I suppose to get 5mm u would have to do 2 coats.
Come on mate own up its "your" bedroom wall isnt it
damn you marshy poirot.......................Come on mate own up its "your" bedroom wall isnt it
Is he your son on the photo?
Aye. That's wor HarryIs he your son on the photo?
I bet you raking it in being his managerAye. That's wor Harry
