Plasterer paton
Plastering for over 20 years, had to buy this as couldn't get British gypsum multi finish. Biggest mistake av made for years, its basically crappy filler . Dont recommend!
You're the first person to mention this gear on here. I'm sure that if you did a search there definitely wouldn't be a dozen other threads on it.Plastering for over 20 years, had to buy this as couldn't get British gypsum multi finish. Biggest mistake av made for years, its basically crappy filler . Dont recommend!
used it for the last seven days with varied results,needs a fair bit of water for the final trowel,I've been using a water butt and an elephant.
try sponging it a couple of times.
