maybe baby
ROTORS & STATORS for plasters, cements & coatings​
Stock no Description Max Output U se £ ex VAT​
182005 D6-3 rotor 30 ltr/min plaster, PFT type 49.00181505 D6-3 stator 30 ltr/min plaster, PFT type 39.00182003 D4-MV rotor 30 ltr/min plaster, MTec type 49.00​
181504 D4-MV stator 30 ltr/min plaster, MTec type
TUT TUT TUT
The M22 is a spray unit with a 3kw central motor,material hopper feeding the mixing chamber, waterflow regulator and bottom outlet screw pump; themachine includes an on board compressorThe pump is designed for mixing, pumping andspraying pre-bagged mortars and plasters thatare formulated for spray application. The M22 willpump and spray one coat projection plaster andalso hardwall. Suitable spray plasters are producedby British Gypsum and KnaufFor plastering, a three man gang can spray, rule offand trowel finish about 25 metres per hourDry powder is fed into the main hopper, mixed withwater in the mixing chamber and pumped throughthe 10 metre hose to the spray gun and nozzleThe pump is supplied with spray gun and externalrubber nozzles, 10 metres of material hose andremote switch and lead. The M22 is a three phasemachine requiring a 415 volt power supply and aconsistent water supply​
Generator required, 9 kva
d*m**o these machines are quite old tech butt.......ageing designs and basic technology all badged up that's all. If they were a bargain and you knew what you were doing then tidy darts but certainly not for the uninitiated. No backup just sales too
goodys right you will get no back up and service with these people . talk to people who use machines day in day out
they will tell you how good it is to know help can be just a phone call away and any parts you need are there next day:rolleyes)
Kinel av they just been robbin parts from round th back of pft gmbh or summit, or did they just nik the paint
