Mechanical fixing plasterboard
Daveo82
I'm struggling on space so want to mechanically fix foilbscked plasterboard directly to the wall (9inch solid brick) is this possible?
Just ditch the foiled back board, use dryfix foam on ordinary plasterboard, put a few mushrooms through and skim it, you'll lose 20mm if you lucky
Foilbscked to stop any moisture passing through - to face mess for cost of going back to brick and S&C the walls
Just wondered if it was possible
Your bodging it and if it's a customer you will get a call in the future, plenty of posts do a search.
