Method statements
Ivor
Iv been asked to supply a method statement and risk assessment for mono can anyone point me in the right direction please .
Its not really about the mono mate. Its the job specifics. Work from scaff, what tools electrical wise etc, insurance cover, any hazards at the site blah blah etc
i have one for mono ,load of **** as said ,download webers spec and just print of the method ,the risk statement is as for any form of plastering ,dust ect ,print of as much as you can ,they never read it anyway ,just print a big headed page for the site you are dealing with ,ie name site /contractor
Risk assessment templates are available on the HSE website to give you an idea. Method statements is basically a run down of how you are going to complete the work SAFELY. Include things like scaffold towers to be erected by pasma trained operatives, tools and equipment to be in good working order and 110v only, PPE that you will be wearing and a description of the work itself( render will be applied to thickness of 18mm by hawk and trowel and ruled off with a serrated straight edge to leave a flat surface, render will be closed in with a spatula and left for x amount of hours before being scraped with I section and scraping tool to get desired finish. All waste and debris will be removed and placed into on site skip at the end of each working day. Ect ect hope this gives you an idea include everything but as long as your to the point there's no need for pages and pages but don't turn up with just a paragraph.... Good luck
Blue Steed Construction Ltd 59 The Bishops Avenue.
Method Statement for skim-cost to Garage Internal Ceiling
Scope
MF plaster-boarded ceiling has already been installed inside the garage. A thin skim plaster coat will be applied working off platform created by 50Nr small bandstands fully boarded to form safe working area.
Conditions Survey
Prior to any works being done, all doors, walls and ceiling surfaces will be inspected to note any damage or deviations. Garage doors have been fully painted and must remain covered to prevent damage.
Risk Assessment
The risk assessment takes into account managing and reducing risks by having detailed look at the area for safe access and egress. This needs to be limited to only one door. No access is available in the loft space via new loft ladder.
The floor has been protected by Bowen with polythene covered over with taped 6mm plywood sheets.
The internal area has a level, safe, fully boarded area of small bandstand trestles for 60% of the area; at about 650mm high, giving a height of 1850mm to ceiling level.
There is ample back-ground safety/task lighting; and all materials needed for skimming have been placed inside the garage.
Risks from trip hazards and falls have been reduced by keeping area clear as well as having scaffold boards close to the walls.
No other trades will be allowed in the area except for the plasterers.
Safety goggles are to be worn if there is any high risk of splashes into eyes.
Bowen are installing 240V convector heaters in the garage to maintain ambient temperature necessary for floor resin works which will follow on from the skimming.
Method Statement
Multi-finish to be used for skim-coat will be mixed outside the garage to avoid splashing the doors and walls.
Works will start at west half of the garage.
At suitable stage, the existing platform will be moved and set up over to east half of the garage until all the ceiling area has been skim-coated.
At east end of garage bay Nr 5 there is a 5.8m x 0.6mm wide slot in ceiling for a future timber access panel. The edges of the slot will have skim-coat angle beads fixed and plastered to form a neat edge, which will give a 6mm shadow gap.
There is no shadow gap detail at the perimeter wall junctions.
At approx centre of each bay there is a single cable inserted through the ceiling for future wiring of door-automation units. This cable must remain intact.
Once skim coat has been applied, all boards, trestles, floor protections will be cleared from the garage to make way for floor resin.
The internal area will be left overnight with 240V heaters by Bowen.
Plastic protection of doors will be removed and returned to BSCL for later use during internal decorations of the garage w/c 7/2/11. Please note BSCL have not allowed to protect the garage floor with correx sheets.
Signatures:​Date:
1…………………………​…………………………….
2…………………………​…………………………….
3…………………………​…………………………….
