User________removed
Got a job to do shortly refurbishing a fire place, basically being opened out to take a log basket. The inside is being done with sand cement and lime, with the breast being rendered also. The problem being that the breast is being extended out to the side with stud work so that it can house a large vertical opening where logs will be stacked, so will be boarded.
My thoughts were to dab cement boards across the face of the breast over the stud work so that it can all be rendered in one, she also likes the scraped texture of mono and wants the breast done in this. but not the inside. So is it doable to dab cement boards ?? and would they take Monorex GF ?? anyone use mono on internal stuff ? im thinking it would look quite good, as a feature.
Cheers AB
Cheers AB
