monocouche
ian
hey up lads.. can anyone advise on applying monocouche .. do i need a special base mix and then topcoat over with monocouche.. my desired finish has got to be smooth..many thanks
im goin over brickwork and some block work which has been painted , will i need to use rend aid first ?
yeah was goin to mesh out... the brick work is really bad internally
If the internal brick work is so bad then you dont really want to be drilling mesh int the wall, scrape the lose and flaky stuff off and rend aid it jobs a good en
If the internal brick work is so bad then you dont really want to be drilling mesh int the wall, scrape the loose and flaky stuff off and rend aid it jobs a good en
Unless your going to use Panzamesh to bed into the adhesive coat your not going to drill the wall eh
Painted blockwork will be ok Rendaided because it tends not to be flakey and horrible, but i see what the blokes are saying about brickwork i dont think id chance painted brick me self,
