Monojet advise
wiganlad
Where's the water filter that needs cleaning. Also for som reason the water out let for setting the mixing level seems to be full of crap after every spray . I never had this with the g4 ! Am I doing somet wrong. ( set float level the atatch pipe to mixing zone top one. Set level and put cap back on once water has stop completely . Prime r&s then just check level hasn't dropped by opening cap and pressing water till it comes out again n replace once stoped. StArt motor n add powder. Once I've got right mix stop motor. Atatch pipe n airline turn on comp then motor then spray away
We always have to clean the outlet pal on ours. Just stick the hose pipe in when your cleaning down both holes til it runs clean. Stick your finger in to check its clear
Was it clean on the g4 ?
I think its normal pal coz the water enters just above it so wet mix should be all around that level
Yeah pal . I always squirted water down n used the file inside it . But it never came up n filled with plaster the bottom one I mean not the inlet
You have two water filters? One where the the water in pipe fits. Take off the rubber grommet and there is a wire gauze filter. The second one is under the caddy and you need a wrench as it is a big brass nut. About 30 mm . Take the caddy off to get to it. I don't understand the full of dirt thing, the only thing we had was perhaps a bit of rusty water coming out on priming if it hadn't been used for months.
check your water priming hole in the chamber for getting bunged up.
try putting less water in for initial start up. instead of waiting till water comes out of bottom inlet. only fill it to half of that
chers bud i tried ringing yesterday re the filters but it wdnt conect. I knew about the one on the inlet the gauze but cudnt see the big one any where. Cheers pal
