Monojet advise
wiganlad
Right after my little problem with the electrics ( spark fixed the lead sumet wrong with the 16 amp socket ) I've set every thing up at home as I am doin on site water butt and pump and genny,. Now b4 the electic problem the water kept on dropping in the float. I had a look and ther was quite abut of build up in the inlet I've cleaned all out now. So I'm set up but I've taken r& s of and ran a full water butt through the machine the float dropped initially about 4 ml but after that stayed consistent until the full water but was empty. I'm i right in assuming the machine is running fine and my set up is ok and any problems that will happening now will be down to if I start up wrong . Cheers appreciate any input
Could possibly be something simple like a washer inside the adjust tap on the flow bottle has worn out, when the water has dropped rather then manually turning the water back up just give the adjustment tap a little tap with your finger and the water should come back up and then stay up
Cheers stu. It's the start ups I have all the fun with. My jugs go back to sumet with star wheel if I keep getting the back up of powder
