Monojet electrical prob ?????
wiganlad
Cleaned it out last week coz I had a water flow prob. I had a build up in the inlet to mixing zone( my fault ) . So I had a drill in side n cleaned all the hard wall of. Anyway plugged it all back in set all back up switched it on and nothing. I'm running of a tank with pump. The leads are fine coz there are sum heaters on site running of 3 phase so I tested on them it they worked
plug a heater into your lead if it works you can eliminate the lead. then check you have plugged everything back where it should be.
Did that already with the heater . N i plugged into the caddy. Then plugged in the pump. Comp and motor. Turned switch and nothing. I'm almost certain it's down to my error sum where . It just come from a service with lez n I don't believe for one min these things just stop working. I'll run through every thing again Tomoz to be sure
Have you tripped it? Happened to me once. Inside the caddy there are some trips. Can't remember if they pop out and want pushing in or vice-versa. Blue I think in colour but have a prod around inside the caddy and look for some little bits of plastic not in line and do some prodding.only a couple of mm.
