Monojet problem solved(I hope ha)
wiganlad
We'll thanx to Ian jones my new pump arrived yesterday and I sprayed today. And I must say faultless from start to finish. 35 bags of hardwall without hiccup . Thanx to Ian and Stuart for being patient with me bugging them on the phone and essay length txt to Ian. Also any other advised from the lads on here. Let's see if I can repeat Tomoz
What was wrong lee
Pump wasnt runing consistant. Was droping prsure gradualy resulting in a mixing zone full of dry powder. And me looking like a right boob only sprayed for
An hour today but i plan on hitting an extra 50m tomoz so fingers crossed
It's hardwall ,inside a concrete building budd we not feeling the weather thank god. 2 lads on the rule right behind me . The walls cdnt get any easier which is about time they the only ones in 30,000 m2 without beads ha
sorry mate thought you were doing mono :RpS_scared:
What part did it need to fix it Lee?
Just the water pump john . The flow and pressure was dropping after a few minits the float went go pas 1. All gud now buddy got the av1000. Wud of gon for the 3000 but I'm trying budget a little with just laying out for the machine a new gun 1k to get my van back on the road and lost days and still lads to pay. Had a bad run ha. Keep goin wit yed darn though.
I have bought the AV1000 for the Ritmo with a pressure switch fitted. Should be ok for a few years. Hope everything is ok for you now.
We'll I went in Friday and was sprayed up for 8:30 and by the time I'd cleaned the machine the lads had ruled off. Was a long wait to skim though . Gave me plenty time to rub up and prep for Mondays work.
We have been floating one day setting the next. Wetting the walls with a mist then leaving 15 mins before setting.
