Plasterers1stopshop is the mtec 100 a better machine than the ritmo in your opinion? I take it, it does virtually all materials krend, multi, knauf etc
in our opinion yes it is. There are others who would disagree though :-(
The M100 as standard is only for Plasters. For Renders / EWI you will need to buy the attachments.
If you head to our Facebook page and go to videos there is a great video of a customer spraying MP Finish through the M-tec M100.
Hi JDplast. If you change the rotor/stator pump on the bottom, use a 13mm pipe & a stainless steel powercoat spray gun then then the same ritmo will mix and pump finish plasters. Out of interest where did you buy the ritmo ? Was it New?
