question 1 i know theres various factors that alter this curing time including surface, ventilation, room temp etc.... but roughly is it about 30 mins after mix to get your first coat on before starting back at same place for second coat???? and again you got about another 30 mins to get this on?????? i know your ment to finger test it but just wanted a rough time scale????????? thanks pro's
question 2 also incase you hadnt guessed that i'm new to this..... ive been told you can buy stop bead to separate big area's..... where from???? looked everywhere i can only see angle bead......
and finally 3rd and final question can you use plasterboard beading on normal walls or should you only use mini mesh beads??
Thanks pro's
Thanks pro's
