Nela max
John j
Mono Don
Been using mine last few days after wet trowel as seems to finish it easier then with steel.
Anyway as you all know you get them scratches . I.ve seen em before and never see em once it's been painted. Cant even feel em. But wondered if they show when suns down wall . Took couple of pics . The camera shows a lot of grit in one pic I couldnt see with eye. Wall lights on this wall as well
Anyway as you all know you get them scratches . I.ve seen em before and never see em once it's been painted. Cant even feel em. But wondered if they show when suns down wall . Took couple of pics . The camera shows a lot of grit in one pic I couldnt see with eye. Wall lights on this wall as well View attachment 50438View attachment 50439
I dint think ull see them but dont you take the grit out? Or get it on thicker?
Rub the edge of blade in circular motions on a plaster board before you trowel make's the blade flawless
To be fair I couldnt see the grit until I looked at the pic. But I done a good job getting a pic of the scratches
Funny as I watched a programme with titchmarsh in other night and never knew chilles grew like that
Bet you wanna go out and get some now! Il make you moderator in chilli club if you join (y) You will have to be quick though I’ve only got a few spots left:ROFLMAO:
Even the pissiest mist coat would hide most of them i reckon
Two coats more on top too.
As above plasterboard works to hone the edge.
I found the finest sandpaper (800 grit upwards), and a couple of steady strokes along sorts it. Slowly does it, too fast and it can melt/chew it.
I.ve seen em painted loads . Just wondered if sun shows em
Wet n dry sandpaper sorts plastic towels out..f**k knows what grade it is but its black..not in a racist way tho
Yes mate, black/dark grey paper, smoother the better on them plastics.
High grit is a bit specialist, harder to source.
It should say grit number on the back of the paper.
