New renders
Yes, takes some getting used to but researching words used makes it understandable eventually.
Latest term: Glancing Light.
One o’clock shadow.
A wall that looks perfectly flat until the sun is at 1 o’clock position. Looks like the North sea in a forcy 10 gale.
Is this bad rendering job when it look like this.
It will show a bad job up, but what looks perfect will show the slightest blemish.
Observe what time the 1 o’clock shadow comes or the 11 o’clock and if you get a complant don’t go back at those times.
U can been the next j.a Taylor. I think it was called in the 70ts
Think its J B Taylor.
I have his 2nd edition still. Bought in 1972.
I refer to it for a wet dash mix. But what is interesting, in that book he illustrated a scraped render method. Using a sharp sand you render to flat and when ‘green’ you rub up with a wooden float that had beer bottle tops screwed to it.
What he was referring to was what we refer to today as monocouche.
In 2000 it sounded like a new modern render finish just been invented. When it had been a method used years ago.
I witnessed a renderer doing such a method in the 90’s. Conventional sand and cement then rubbed up with what was probably a scratch pad bought on the continent. He used white cement.
I thought it looked naff but this man kept his method to himself, was not local and was sought after.
A good book in its day.
One o’clock shadow.
New renders
New renders
New renders
same wall. Sun is a c**t
