New tools
Smudger1
I do a bit of tiling nothing fancy and use a small push through electric wet cutter.
But job on now the tiles are bigger and thicker for the walls than I usually stick, so I got this today after reading up it sounds good for the money ?
Virtex 800w bridge cutter from toolsatation for 175 inc.
Should cut straiter than small one I've got.
Also once mixed up adhesive I stick it to wall with bucket trowel then spread it out with my notched tiling trowel. Is there a better way ?
ChrispyUK
View attachment 25526View attachment 25527
I think apart from actually using a hawk and trowel, prob not mate. Often in same predicament, but just end up using tiling trowel to load the wall and make sure I've got a full notch in one direction. On the last few large format porcelain jobs I've done, I have used the new plastic leveling clips and wedges. Can recommend those if you haven't already used them.
Let us know how the bridge performs :)
Smudger1
Will do. I've only used the clips n wedges with floor tiles ,just ordinary spacers on walls.
Danny
Administrator
I have never done any tiling :D :D Dont know why I have not but one day I will know what it is like to lay a tile :D
ChrispyUK
I have never done any tiling :D:D Dont know why I have not but one day I will know what it is like to lay a tile :D
All in the prep really Danny. If the wall/floor is as flat and true as possible, then you're 75% of the way there...pretty much.
When you think about it, skim/walls are either painted, papered or tiled and a good spread should have a reasonable understanding on how a room needs to be prepared for tiling.
Danny
Administrator
Oh yes I am sure it is straight forward enough :D Cant imagine it being rocket science :D
lurpak
Artex Boy
Use a hawk n normal trowel spread whole area then run notch through
Tilers would frown upon that probably but I’m a spread so don’t care lol
If you try butter wall with notch it always ends up all over the trowel
Smudger1
There is the smooth side on the tile trowel so could butter wall with it but only if I had a crappy hawk spare, I wouldn't feel right dirtying my good plastering hawks with tile muck ! :chica: but the bucket trowel then tile one works ok for me. :coffe:
Glad to report the bridge cutter worked great, well chuffed with it so far :rock:
Couple of top cut pics I did today with it.
Danny
Administrator
View attachment 25568View attachment 25569
looks great to me
ChrispyUK
Looks good mate. I always try and lay large format straight knecked like youve done. Running bond is a bit dated IMO.
