hi guys
i had recent news the missus was going to drop in about 7 months time. we have a 3 bed semi and have had the main bedroom done for ourselves. we have decided to make the larger of the other 2 rooms for the new arrival.
this room measures 3.7m x 3.2m x 2.6m high. i had a plasterer look at it about 18 months ago and he recommended all the plaster removed as it had failed in so many places. walls and ceiling, its lathe and plaster on 2 internal walls and solids on exterior and party wall. party wall has chimney beast and 2 alcoves. i have removed all lathe and plaster and knocked off all plaster from solids to bare brick. also one alcove has a combi bolier there. havnt done ceiling as i was thinking of putting in a false one. ceiling has built in curves coming down to the wall which i dont like. i have lots of questions especially after reading ballsdeep story of the ceiling which came down. clearly the ceiling wasnt strong enought to take the weight of the boards and plastering.
i have lots of questions for the professionals really. i normally get skilled in to do all the work but theres a recession on and i have had so many cowboys that im gonna give it ago myself but get a plasterer in to do the final finish. i know i would mess that up that but i dont mind doing the ceiling and boarding out the room.
ceiling in first.
1. what size timber to frame out the ceiling?
2. distances timber needs to be apart for strength?
3. noggins inbetween to strengthen more?
4. what size screws to make sure plasterboard stays up?
5. if i lower the ceiling from the original, can i put insulation in the cavity?
6. do i need to tie the new ceiling to the roof joists for more support over the 3.7x3.2 distance?
walls next (studded}
1. im working on my own, so to hold boards and screws need to be how far apart?
2. whats best method to ensure radiator brackets have a secure fixing? pipe work already in place so not guaranteed to hit timber frame with screws?
3. 2nd studded wall has timber frame but with bricks inbetween but only half the wall and only half way up??? this parties the bathroom which has been fully boarded out and tiled, so no heavy banging???
solid walls
just the best method to dot and dab really. i feel confident enough just to dot all over the wall and level board.
1. do i board the window out first?
2. how do i stick the metal beading on the corners around the window and chimney breast?
3. do i need to "key" the walls first with pva?
4. how far off the floorboards do i need to be with a gap?
i know this my sound childlike to you skilled guys but i want to do i properly and need your help please
thanks in advance
danny
ceiling in first.
solid walls
thanks in advance
danny
