Why not use base coat?Can I just use one coat render or Kmix, for thin coat or does it need to be polymer render, going over brick
Are you not more tempted with OCR’s being easier to spray than poly modded.Why not use base coat?
I actually prefer base coat to spray and to work with I find it faster as well,Are you not more tempted with OCR’s being easier to spray than poly modded.
I’ve done it a few times with good results.
All my work is guaranteed so has to comply with manufacturers specification BBA cert is required in most casesI actually prefer base coat to spray and to work with I find it faster as well,
