johniosaif
Hi, just viewed an old end of terrace ,which needs rendering , I do normal sand and cement work, if heroes for a colour render,will post it here.its hacked off perfectly. I would normally, soak it down ,give ita splatter coat with sbr ,so sand and cement slurry with sbr rather than sbr slurry brushed on.then a scratch with
Waterproof,say 4/1 sand cement,leave it 5 days or so then float with 6/1/1 sand cement lime , all hand applied, lovely big flank wall ,so a bit of work in it, three lifts on the flank. Probably put fibres in it also, isitworth wishing? I'd need one with 8mm holes ..cheers
