Hi, new poster and just a DIY renovater (hope it’s ok to ask a question) with a new house - well a very old house .. 300 year old cottage with 1969 extension (living in extension, working on cottage which is a separate building ). Started taking down the plasterboard in the old cottage (stripping back to limecrete walls) . All seems normal enough until the bathroom. In there the plasterboard is spaced from the walls using big dobs of plaster (not timber Latts as before ) but also the plasterboard has the brown side facing out into the room which is different from everywhere else in house . There also seems to be an extra ‘layer ‘ of what looks like plasterboard under the window - I think it’s plasterboard and not AIB as there is paper on both sides , but stand to be corrected. There seems to be two layers of plaster as well in bathroom. A thin one on top (maybe 3 or 4 mm with the paint on top then one below that’s about 8mm) both are hard , brittle , will break when banged on hard surface and comes away in chunks. In other parts of house it was just one layer of plaster . The plaster boards are joined with metal mesh at the window corners then cotton scrim elsewhere. The cotton scrim has a sparkle in it, only noticed as the bulb went and I was taking a second look with the torch. When I shone light on it it has what looks like glittter. Between this and the extra ‘layers’ asbestos has come to mind. I am wondering would double layering plaster boards in spots like under window have been a done thing? And is it normal to uncover what looks like two layers of plaster and then there’s the glittery scrim... Any thoughts from the professionals ? Have stopped work. Was working in those papery painting overall’s and FFP3 mask with window open. Have closed window and the door on the room for moment and wet wiped shoes phone tools etc. Many thanks in advance for any advice , L
