Hello everyone,
I've got a small extension that needs rendering, covered in pebbledash right to ground level.
Could i chip off the pebbledash and render over that to the ground or what issues would i have with damp? it's been like that for a good number of years and there's no sign of damp inside. The internal floor height is quite high compared to outside ground
Also, the old window was right beside the boiler so window's been replaced so it's at least 300mm away and been blocked up.
Can i scratch coat the blocks to bridge the depth gap of the wall then scratch coat the whole thing then top coat?
The garage is exactly the same with pebbledash right to the ground
Thanks very much in advance for any help
Greig
Greig
