Hi Guys
Looking for a bit of advice. I'm a plumber who's half decent at skimming with multi-finish on plasterboard in my own home only. Have been roped into fitting new bathroom for my sis and offered to try to tidy walls up a bit. Big mistake.
On removing the bath and tiles found that the wall behind is what I've since discovered is called paramount or egg box wall. The other walls are painted plaster on breezeblock.
My question is the best way to prepare for skimming as I have only ever plastered PB. I don't think the paramount wall is damaged too much as the wall was painted underneath the tiles.
Q1 Should I leave well alone (not bother over boarding) and just tile it again,scratching and sanding the surface first?
The other walls were quite bad and painted to a shiny finish so I have chipped the top surface off (painful ) which has left the exposed render.
Q2 How should I treat the exposed undercoat to control suction in readiness for skimming ?
New to the forum have found it really helpful.
Any advice would be much appreciated.
