I've been using it after flattening straight through it's way stiffer then any other flexy trowel and the spine/plate is much stiffer too this trowel actually flattens stuff lol but I have been using it on boardA trowel with rivets is a totally different one that has sticky tape lol!
Yes mate there the b*ll***s! I'm a big fan of Kraft trowels very well made piss all over marshaltown!
Yes the midiflex is not that great in my opinion, this trowel is a much better version way stiffer does not warp back when you apply lots of pressure and it actually cuts through the plaster rather then riding it on the later trowels so you dont have to hit perfect everytime and potentially ride an imperfection.Have you used a mediflex as comparison? I’m thinking of trying one after feedback on here.
LiesI have both they are the same flex wise and the Kraft is heavier
Go kiss your dadIf you cant see it you must be special
Sounds like it I haven't used that one thoughSounds like this must be similar to Refina s*p*r*lex 3 then.
A couple hold hands as the final push releases what they assume is a beautiful newborn baby.. the doctor turns around before they can even see it and looks back and says "You want the Good or Bad news?"Cmon you can do better than that
I haven't tried it mate always Marshaltown SS for laying and flattening personallyGot a s*p*r*lex 3 already,
Dont need another.
Spoke to Ian (blones) the other day and he said you can use it start to finish, so now tempted.....
Love Kraft gear...
Maybe....
It's not and blones chats shiteSounds like this must be similar to Refina s*p*r*lex 3 then.
Go on this site mate they got a good range of Kraft and everything else to be honest! I buy all my gear on there.
YesSo Is the opti more flexible than the refina #3?
Would you use the refina over opti?
I Got enough for now Haha but would do you think of the ss normal trowels I have a midget Kraft trowel and it's very nice but feels stiffer then marshaltown tbhGo on this site mate they got a good range of Kraft and everything else to be honest! I buy all my gear on there.View attachment 35033
I'm not disputing the corners pull easier they have no strength but further down it feels much more resistant then the midi I'll have another check lolGet the option and the media and bend one of the corners back with your hand both the same
Gibbo I need to tell you somethingMy Marshall is just as flexible but try bending the corner goes back straight away
straight mate dont do the muddy pathGibbo I need to tell you something
I was wondering if..
You could love me back..
£150,000?I'm
Thought medi was good until I tried MT permaflex. How does Kraft compare to MT?I have both they are the same flex wise and the Kraft is heavier
