Takes no more time and a very small amount of extra work. No brainer to put beads up, and looks a much better job. only time I would skim to old bead is if their was a radiator under the window and the customer didn't want to take it offDoing a over skim next week one wall. the wall perfect spark be ther so need to fill socket and one chase reveals are spot on. What I usually do when reveals are Ok just feather in to the bead How many of you would put new beads and re do reveals on over skim?
Guess so you can get away sometimes best job rebead and depends customer whantsDepends if the last spread filled to the beads or scooped them. Re beading scooped beads skim goes on about 5mm, skim doesn’t like going on 2mm sometimes.
I alway take the rads of myself, each to there own though.Takes no more time and a very small amount of extra work. No brainer to put beads up, and looks a much better job. only time I would skim to old bead is if their was a radiator under the window and the customer didn't want to take it off
Don't touch the rads I just tell them if you whant them off you get a plumber. And if ther ther when I go back I skim as far as I go. and really you don't notice who going to see behind them o yes the spidersI alway take the rads of myself, each to there own though.
Did you understand why in some cases the existing bead is scraped back ?New beeds . Priced on job. Make life easy
What if there's a cill onDid you understand why in some cases the existing bead is scraped back ?
Mate you no idea how rough I am lol . Ain't got time for s**t like that curtains will hide itMy point was ,,,, check the bead with a straight edge against the wall , horizontally in the case of vertical bead , the wall might already curve in away from bead , if you stick another bead on top you could be making life difficult
