Hi all,
I need to plaster a dining room ceiling that currently has artex on. The peaks on the artex are between 10mm-20mm. I have taken a small sample and will be sending it for testing for asbestos. If by some miracle it comes back clear then it`s a scrape and overboard but if not I can`t think of an effective way to overboard it with the size of the peaks. That`s a hell of depth to put bonding onto a ceiling! I did think about expanding foam across the ceiling inbetween the peaks to take up the gaps and then board but would welcome any other ideas.
Cheers
Cheers
