jamesthefirst
Anyone use the gyproc joint filler or similar to bed on paper tapes, looking for 25kg bags probably by other companies?
Used gyproc joint filler and easifill but only when actualy tape & jointing
Gtec do good joint filler and joint cement.Anyone use the gyproc joint filler or similar to bed on paper tapes, looking for 25kg bags probably by other companies?
Beat me to it. Made by gtecWondertex gets mentioned every now and then, I never used it, only premix
Are you on Facebook James? There is one dryliners page on there where they often compare notes on products. I'll have a look.Anyone use the gyproc joint filler or similar to bed on paper tapes, looking for 25kg bags probably by other companies?
Ccf own brand tradeline ready mix is my preferred choice tbh
Used gyproc ready mix and trade line at job if bedding tape in gyproc was fine but for sanding down of joint I’d go tradeline everyday of the week, gyproc was mental to sand back had to use grit 80 on Makita hand held , nearly killed me off
