patch repair monochouche
richard pitman
My plumber went and blew the back off my new rendered wall. Its Weberpral M in chalk.
Is this an easy fix?
its about 30 x 30mm minus the core.
Tell your plumber to fit a pipe collar. I'm more interested in how the top layer of render managed to pop off the apparently flat bottom layer with no sign of any bonding.
Tell the plumber to drill in not out next time ,and create 4" band around the flue with same render
Sent from my SM-G930F using Tapatalk
Just tape around the edge of the repair so you don't damage the good render when you scrape it back and just patch it on with the same gear. Leave it proud and scrape it back. Happens all the time with plumbers. It will weather in over time.
