plants growing through render
rgp
Evening all
I need to render and old outside wall which have these large plants growing through. does anyone know the best way to kill them off ?? Not sure if weed killer is going to be strong enough.
Cheers for any advice
  • plants growing through render
Ive seen this a lot starts off a small weed next thing a tree dig it out at the root , or "It will be Return"
I recently emailed Jeyes to ask if it can be used as a biocide to kill moss off instead of using the manufacturers expensive stuff. Apparently it killed everything off at one time but in recent years they have had to weaken it to comply with EU regulations. There answer was no, it doesn't so I don't think it will kill this triffid off. At least try a good weed killer but as Flinneyman say's take a brick out and remove every trace of root or it will be back to haunt you, preferably after using weed killer.
Anyone old enough to remember the film about Triffids taking over the world?
ok thanks for the advice there is quite a lot of it dotted around the wall so i could end up taking half the wall down but i will give it a crack.
thanks
