First of all sorry if I am asking anything silly...
So I plan to tile bathroom onto plasterboard.
The plasterboard is going to be dot dabbed onto brick. I am going to PVA the brick first.
I want to screw plasterboard on as well to be sure it's fixed.
Can I drill pilot holes and put plugs into brick, then dot dab, then screw (while wet).
Or do I dot dab then drill through, put plug in and screw
Also once done before I tile anything need to be done (prime? If so with what?) (Tape gaps?)
Thanks for any advice in advance..
