jamesthefirst
With boards classed as hazerdous waste do you think a new type of board will be invented. If an 8x4 was the same weight as one piece of coving and so strong that you didn’t have to cut them on the half joist. No waste.
With boards classed as hazerdous waste do you think a new type of board will be invented. If an 8x4 was the same weight as one piece of coving and so strong that you didn’t have to cut them on the half joist. No waste.![]()
I don't get any wasteWith boards classed as hazerdous waste do you think a new type of board will be invented. If an 8x4 was the same weight as one piece of coving and so strong that you didn’t have to cut them on the half joist. No waste.![]()
I had a meeting with a BG rep about ten years ago and he said that they (BG) were going to try and push for float and set to become the norm again, to cut down on waste. I told him that there wasn't a hope in hell of that happening as there wouldn't be enough tradesmen with the right skillset to cover the work and that builders wouldn't want to pay the right money to those that could do it.
I think that comes down to corner cutting , poor choice of muck to use coupled with a lack of prep and being rushed to get it doneIs it really less waste when it blows 10 years later n has to all come down
All offcuts stuck in cavity of stud walls for extra sound proofing if your not using them to join ceiling boards mid joistWith boards classed as hazerdous waste do you think a new type of board will be invented. If an 8x4 was the same weight as one piece of coving and so strong that you didn’t have to cut them on the half joist. No waste.![]()
Many compost recipes have a proportion of gypsum in themWhats in plasterboard that is hazardous? I know it has fiberglass in it but that is only glass or isnt it?
I thought gypsum was just stone/clay?
Yours might have blown in ten years time but mine will probably still be there in a hundred years you muffin.Is it really less waste when it blows 10 years later n has to all come down
Not a good idea and too time consuming , stick them in the cavity, I keep any leftovers for the next job , great for soundproofing toilet/bedroom stud wall in particular, better than nothing , half a bucket is skim and stick all over, overlap gaps with different layersA builder I worked for 20 years ago put loads of off cuts on both sides of a stud to block up a door! He was ahead of his time., although I used half a roll of scrim lol.
If you use the right material it shouldn’t blow it shouldn’t blow, I’m with Andy though, there probably would be a massive shortage of spreads that could do itIs it really less waste when it blows 10 years later n has to all come down
Knauf still do , BG boards on stud walls as better sound absorbing , being too soft for ceilingsI remember that, the days when boards used to cut nice and crisp as well
But how do you get the proper sound insulation in if it's filled with offcuts?Not a good idea and too time consuming , stick them in the cavity, I keep any leftovers for the next job , great for soundproofing toilet/bedroom stud wall in particular, better than nothing , half a bucket is skim and stick all over, overlap gaps with different layers
I don't work on new builds so not working to spec and most of my customers are looking to save £ , penny pinching no doubt , but I give them the choice , have often stuck one layer in and rockwool which easily compresses , may have some mad ideas Andy but never proceed without full explanation to customers , at the end of the day I will conform to the norm it's up to them , I'm just paid by the hourBut how do you get the proper sound insulation in if it's filled with offcuts?
It's a bit like jointing ceiling boards mid most and double skimming , these are methods for occasional use , it's for discussion ,everyone shoot the idea down and have a laugh I don't mind as I'm looking for faults and improvements , I get my laughs from plenty of so called spreads on here who quite frankly should not be allowed to even mix up , full offence intended ( just for fun )But how do you get the proper sound insulation in if it's filled with offcuts?
I’ve made a concerted effort to apply backing coats instead of using plasterboard recently, you in an ideal situation to use Ritmo to do the same tbfI had a meeting with a BG rep about ten years ago and he said that they (BG) were going to try and push for float and set to become the norm again, to cut down on waste. I told him that there wasn't a hope in hell of that happening as there wouldn't be enough tradesmen with the right skillset to cover the work and that builders wouldn't want to pay the right money to those that could do it.
And Andy would you bother to machine one room, how much would have to go on for it to be worth it,I’ve made a concerted effort to apply backing coats instead of using plasterboard recently, you in an ideal situation to use Ritmo to do the same tbf
I would mate , think about it say even a small 3x3 room as example roughly let’s say 12 bags hardwall compared to take all boards in cut them then go get driwall and mix that then dab and apply them , he’d have the whole room floated by 11.30 am go for dinner come back and skim it and materials cost would be less , more profit for himAnd Andy would you bother to machine one room, how much would have to go on for it to be worth it,
If I'm floating I use box screeds and that doesn't work well with a Ritmo. I'm just not a fan of free ruling on internals.I’ve made a concerted effort to apply backing coats instead of using plasterboard recently, you in an ideal situation to use Ritmo to do the same tbf
A 3 X 3 room I'll have floated in under two hours by hand and quicker still with the Ritmo if I used it. We have done a couple of Hardwall jobs with the Ritmo and it fires it on bloody quickly and with way less effort, no question.I would mate , think about it say even a small 3x3 room as example roughly let’s say 12 bags hardwall compared to take all boards in cut them then go get driwall and mix that then dab and apply them , he’d have the whole room floated by 11.30 am go for dinner come back and skim it and materials cost would be less , more profit for him
Only have to pop the gun through the window into his room and take in a straight edge
And how much does the machine cost , I've been on my own for about 25y and not my market , appreciate the ease of hardwall , miss my younger days with my dad , I'd float SNC and leave him to skim , skimming was for the old and limp wristed ( gaas far as I was concerned , new I would have to take the easy penny one day so enjoyed every minuteA 3 X 3 room I'll have floated in under two hours by hand and quicker still with the Ritmo if I used it. We have done a couple of Hardwall jobs with the Ritmo and it fires it on bloody quickly and with way less effort, no question.
I've no idea how much a Ritmo would cost to fire on render and Hardwall as I bought mine quite some time ago and with lots of extra kit. Which all sits in the unit lol.And how much does the machine cost , I've been on my own for about 25y and not my market , appreciate the ease of hardwall , miss my younger days with my dad , I'd float SNC and leave him to skim , skimming was for the old and limp wristed ( gaas far as I was concerned , new I would have to take the easy penny one day so enjoyed every minute
