phillips900
Hello
I'm new here so please take it easy on me :RpS_biggrin:
I've recently bought a house and am in the process of decorating. The one problem I have is that a light switch has been moved and re filled with filler ( this was done by the previous owner) and the wall is no where near flat. There is a bulge right in the middle of the wall. I've been doing a bit of research and I think it would be too much of a bulge to loose with just 2 coats of multi finish. I would like to try my hand a plastering but I'm in need of some advise. Where would be the best place to start. The walls are breeze block with about 10mm of what I think is bonding coat and then a couple mm of skim. Can I add a coat of bonding to level and then skim over the top of this after its dried? Do I need to pva what is there already or will the bonding coat stick to old plaster?
Cheers
Cheers
