Metal or Plastic Beads? I also have a problem with rusting metal ones in the wall. Also best way to secure the bead to a uneven edge? :RpS_blink: Thanks. V.:RpS_biggrin:
Lots of plasterers prefer plastic, I like the stainless ones myself. You can secure a bead by using screws or plaster or both depending on the edge and depth etc
a few dabs of multi along the edge, then lightly bed your bead. should be able to get it plumb with a level if it's not too far out. wipe off any excess.
you could also staple it or use clouts etc depending on the background. but as above if you can
