Plastering behind radiator
spotpush
I've just removed a radiator and found that the plaster is all fluffy and crumbling off. What should I do with this?
  • Plastering behind radiator
Brush it down, give it a good soak and buy a bag of easifill 60 and give it a couple of coats then sand it mate. Assuming the rads going back that is.
There has been moisture in the wall - damp.
Depending on the reason it may or may not dry out.
Check the pipes and see if they have leaked and caused it.
