CraigC.A.P
Hey guys, I'm Craig I'm a plasterer in Cardiff. I'm looking for advice from some fellow plasterers on my next job, customer has a garage with a bison beam ceiling/floor to room above. They do not want to batton and board as to save as much head height as possible, my question is if you had this job what scenario would you use,
1. Scrape and clean ceiling, paint with pva, bond and skim.
2. Scrape and clean, paint with primer grit, bond and skim
3. Fit EML, bond and skim.
My feeling is that the beams will have enough suction that undercoat plaster will adhere to it but there is always the 50/50 risk of an area failing. Any advice or knowledge from someone who has experienced a similar situation would be great.
Craig
Craig
