this is from your last post there was a problem with it;
Hi James
You cannot render/plaster directly onto the OSB on the outside of a SIP....... Go and ask your SIP supplier!
If this is a new build, you will be building with a system to suit your insurance provider - in order to get a morgage - therefore you will need to have a drained and vertilated cavity, then a render carrier board (such as Knauf Aquapanel Exterior) before the render.... it is a requirement of the main insurance suppliers (NHBC, Prem and LABC)...
If it is an extension, you will need permission from your local building control officer before you do anythng out of the norm..... (remember that you may want to sell the house in the future....)
feel free to get in touch with me for more assistance.
Good Luck!
Richard Lord
Knauf Aquapanel Exterior Spec Manager
07918766577
[email protected]
If it is the inner wall you are refering to.... again you need a board before the plaster..... refer to your SIP supplier for information (different types of boards dependant on the SIP location - if it is a structural element, it will need to be a fire rated board)
Then skim as normal.....
let the forum know where you are based and what you are actually after and someone will assist further with pricing!
Good Luck mate
