Plastering machines
Joro84
Hello everybody, I need your help.
I want to buy plastering machine, I have chosen two EZE K4 and M-TEC M200 .
Most of my work is with hardwall and multifinish.
Please, can any one recommend which of two is better?
I've never used before machine like this.
The EZE K4 wont do Multi Finish - this is more designed for Renders
I have not met anybody that has successfully managed to spray multifinish and made money from it
Don't spray multi finish. Its just not worth it. There is a new pft ritmo out. U should have a look at it. As fast as a k4 and g4. Only 120kg in and out of the van no problem on your own. Don't need a 15kva or 20kva generator to run it. 8.5kva will do the job. A lot cheaper on petrol. Can plug it in to the mains to. And has a off board water pump that comes in very handy. U can pump water to the machine from 30m2 away. The machine will brake in to 3 parts in under 1 minute. Iv the old ritmo 2016 one. Not as fast but good enough for a 2to3 man team. I have a diesel machine to and rather have ritmo tbh. U can put an extension Hopper on the ritmo to. Holds over 8 30kg bags of render. Plus u can use different rotor and stators on it. Clamp maintenance free and soft one. U should go see the k4 the m200 and the ritmo and g4 and then make up your mind. What u think would suit u.
