plastic beading
#1
anybody using the upvc beads for skimming, and for rendering with sand and cement, i know they are more expensive but they are also rust free,just thinking of giving them a go,cheers
choppa
Use them all the time for rendering I thought they where cheaper?
Formby plastering
Plastic arch beads are only needed internal why would you use them elsewhere.
Plastic external are fine with sand and cement used them a few times now.
Groove37
I use them all the time as well for rendering and yes they are cheaper don’t use plastic for skimming as I think personally they are hard to cover
Danny
Administrator
#5
I have used the plastic arch beads and they were a pain.
I also like polishing the metal ones up on corners.. the customers use to like that
zolco
The trimtex plastic beads ideal for skimming, half coat it and it comes out bang on
#7
Use the arch beads a lot on the ewi never had any probs..Where do you get the Trimtex from mate I'll give em a go
zolco
Belmore tools, around 2 quid a piece so it's not cheap
Tinytom
Polish them up with what?
Love CBD
Olican
Bum Fisting Club
#11
Find pvc cheaper than metal. Never used internally though
beader
I like to run my ass crack up and down beads when finished as i find it shines them up a treat....:sisi:
Lodan
I don't understand the scouring pad thing do you mean you scrub down the bead when done to make it shiney?
Love CBD
#28
clean beads, sharp cut off bottoms - all about standards and people remember you for it
Too many f*uckers our there leaving dirty beads and scruffy bottoms.....my pet hate lol
#29
I always clean beads but must admit never bothered with the bottoms. I make sure flat no bumps
#30
I used to use fine sandpaper but now use one of the green scouring pads.
Or just clean water and back edge of masonry brush? There shouldn't be anything on your beads after the last flick they look shiny and new doing that don't see why you would do that other then too look sexy when you work
#31
True that. Should never be set gear on a bead or wil pull bit off reveal when u scrape it. I keep on top of mine. Can just run finger down it at end fook all on it
#34
Hate snots on the bottom,nice neat cut with the trowel job done neat skirting line!
