Personally , we use thin plastic trowels for texturing acrylics on thin coat systems.Some on here I beleive use then on internal finishing. .I suggest you try using it to rub up S/C and see how you get on. 5 minutes in, I think you will draw your own conclusions.
lovely, you allways get 1 mouthy ****buy one you tight c.u.n.t
they aint the same trowels markPersonally , we use thin plastic trowels for texturing acrylics on thin coat systems.Some on here I beleive use then on internal finishing. .I suggest you try using it to rub up S/C and see how you get on. 5 minutes in, I think you will draw your own conclusions.
those refina skimmin trowels are superb for adhesive coats, lay it on with a steel and flatten it with a plassy, very quick results
That just shows the power of the internet, when I first came on here Oasis knew absolutely feck all and asked really really basic questions. Then in no time at all he's putting vids on youtube and suddenly people think he must know what he's doing. I would guess that if you discounted the right 95% of what you watched and read on the net you just might get through to some decent worthwhile information.
the net sounds like this forum then.
Absolutely. The most important thing when using this forum is working out who the very few truly knowledgeable people are in each area. Far to many blaggers.
