f**k itBonding pfffff
Foam it
Bonding pfffff
Foam it
Is that a tirtles flipper stroking her tongue???
If it was w10cm x h20cm x d4cm I would have had the answer,Two tiles came away for the shower wall and the problem I have is that there is a hole in the block work w 20cm x h 10cm x d 4cm. Could you advise on what to use to fill this hole before plastering? Thank you in advance.
Show us picsTwo tiles came away for the shower wall and the problem I have is that there is a hole in the block work w 20cm x h 10cm x d 4cm. Could you advise on what to use to fill this hole before plastering? Thank you in advance.
some flat dick f**k*rIs that a tirtles flipper stroking her tongue???
to tell customer the bills overdueWhats the point in having that pen in the photo unless your going to draw a dick on the wall
As requested, some photos.
