S a plastering
What's the best ratio mix for white pointing mix with snow create got about 4mtrs to do cheers
Oli the original pointing has weatherd so he's not to bothered really it's just on a porch he's had built so was thinking 3 sand 1 snow create what you thinkIf you have the time make up 3 or 4 little batches and leave to dry, this will give you an idea of best ratio to use
3:1 is good. Make sure you have a well cleaned joint at least 15mm deep.
Is 3:1 not too strong?
