pral m
RemovedUser
hi lads iv been given a load of white pral m.
Im planning on using it on a block work wall soon
the problem is how do i go about applying it over celon blocks by hand??
size of beads number of passes scraping back ect
im planning on mixing it in a plasterers bath there's only about 12m2 to put on and finish
there will be two of us both plasterers with over 30 years on the tools just first time trying this sort of thing out.
if it all go's well im planning on doing the rest with mono its only a side wall so its only the neighbour looking at it
we was looking at a fast turn around on finish thats all mono is ready to go no need to go back and paint it ect ect
any help will be most appreciated
Hello mate , Webber stop making white ,how old are the bags you got ? you will need to mesh coat the blocks as they will be less then 7 newton ,i will be honest with you if you have never done it ,get someone in and learn from them ,best of luck
i would be tempted to rendiad celcons mate just for a nice even suction all the way through also mat eliminate any cracking if meshed
Microgobetis the blocks. Put mesh in first coat.
If the bags are old and it's on those high suction blocks, I would put it on early in the day and scrape in the evening.
Dont forget the Maria Carey album for her calming effect.
