Priming with SBR for Ardex K40?
Northers
I have a small concrete floor (~10m2) to level/smooth - around 3mm deep dips to take out. I’ve used Ardex K40 Flow before and like how it goes on. I’ve also got a load of SBR so don’t really want to buy Ardex expensive primer. Can I use SBR as a primer for K40? Anyone done this without issue?
You're just guessing now aren't you mate?
awkward will smith GIF
Most tile primers are acrylic or latex based....
So yes.
Plus I've done it loads of times before.
So yes.
Thanks - I’m going to go with it, concrete should give a good mechanical key and the only problem I’ve ever had with SBR is getting the bloody stuff off. Might do a little test patch first tho..
