Puts eze spat
If that is the same as the Eze spat with pole attachment?? Absolutely brilliant on ceilings but handy flattening big walls too. I use mine all the time and would be lost without it. Saves so much time its a winner :RpS_thumbup: just check its the same tho first pal as @SpankySouthport bought a putz twitcher and its better off in the bin or as a bottle opener!
They are spot on - far far better than speedskim. As it leaves it bit greasy where give you some time. Very similar to Nela flexi. Perfect for ceiling.
Ryan just curious why is bringing all that moisture to the surface a good thing?. The blue blade speed skim also leaves it as flat as, without bringing hardly an moisture up which accelerates the set time.
I have both the putz spat and blue speed skim both are very good, but if I could only rescue one from a burning house it'd have to be the speed skim.
its the tits. everyone keeps jacking off about the nela - mine broke - but this is what you want :RpS_thumbup: i use the plastic blade on mine. superb. few gripes: when you use the plastic blade and then go back to the steel the gap is slightly larger and the steel does not then fit tight because its thinner. it needs a different set up there. they dont do the plastic blade anymore and they should. the pole attachment is too fiddley - too many allen screws when you want something you can adjust by hand, wingnuts or something. everytime you need to adjust it you've got find the allen keys.
The one on there web site mate is stainless 0.5 mm blade that's the one I'm after really if I can
I purchased the new pole attachment now I have both !the new attachment is brilliant for walls as the old wasn't as good !but its a must for board work !I love getting the kit out on jobs knowing am saving time and effort!I have a spare pole if anyone wants to buy it
Also how do they differ from normal spats
They come in sizes 800mm - 1800mm ! Personally I wouldn't go over 1200mm if using the pole for cielings as difficult to get the same pressure over anything wider than that to be fair? On ceilings and large walls they are great and well worth the money they come with s*p*r*lex blade too :RpS_thumbup:
How are they different than the normal hand held spats you can get
Dont go mate, hes fukin grooming ya... if you do go, dont take a coffee from him, it will be drugged and you,ll get bummed...
Just because you suddenly fell asleep after drinking a brew and woke up with a sore botty is pure coincidence !! :rolleyes)
