PVA and tiles
warriorupnorth
sure this may off been broached , but here is a article from another forum that some may find interesting
I have to give guarantees for my work (many of these projects are commercial such as sports centre showers and changing rooms). For me to be able to give guarantees I need to follow strictly the specification of the adhesive manufacturers.
Ardex, BAL and Nicobond are the three suppliers I use most. Their products are similar in many respects, sometimes one will make products the other don't, and I also find some of there products more useful in different applications. All three of them have one thing in common, they all specify that under no circumstances may PVA be used before using any of their adhesives. If you do all guarantees are void.
OK why then? Well I asked this question to Ardex when I once had problem, I'd tiled a bathroom that had been constructed in 25mm Marine ply. Thinking he was doing the right thing, the builder got his guys to seal the ply with unibond PVA...I wasn't aware of this.
I tiled it and 6 months later every single tile fell off the ply, the adhesive solidly stuck to the tile but came clean a whistle off the ply.
We had Ardex Technical down to the site to compile a report, the basis of which was it's the PVA that causes the problem.
When you treat a surface with PVA it partly soaks in and partly sits on the surface of the substrate much in the same way as wallpaper paste.
If PVA gets wet it becomes slightly live again, it doesn't completely return to it's liquid state but it becomes sticky.
When you spread tile adhesive onto the wall, the water in the adhesive makes the PVA live and stops the adhesive from penetrating the substrate and providing a mechanical grip. Basically your tiles, grout and adhesive are being held to the wall by a thin layer of PVA.
Most tile adhesive works by crystallising when it sets (some are slightly different such as epoxy based ones) but generally they all work the same way. Once the adhesive starts to set crystals from and expand into any imperfections in the substrate surface (at a microscopic level) to create a grip. PVA stops this process by creating a barrier between the substrate and the tile adhesive.
Ok so what's the difference between this and Ardex or BAL primer, well basically the tile manufacturers primers soak right in to the substrate and stop the sponge like "draw "effect but they don't coat the surface in any way, they are an impregnator as opposed to a barrier. They also stop a chemical reaction occurring between the cement based adhesive and a plaster substrate, a known problem know as "Ettringite failure"
Ive mentioned this before, on i think the same site there is another article "PVA versus Prime" worth reading.
Lucius
No dont do it Oasis the point is that if you use something other than what the makers reccomend and it fails you got no argument.
Lucius
if its for skimming oasis just carry on with your pva mate its been used for years with no realy problems if you finish falls off a celing afer using say gyprime or bond it BG wont be in a hurry to sort it for you
