Slightly off topic I guess but I got to thinking about dry lining my external facing walls (house is an end terrace). The walls in question are the gable end walls with chimey breast.
My plan was to clean off existing plaster back to brick. Dot n dab with thermal boards. And then joint fill and skim. Was only planning on doing the alcove walls. Is this worth doing? Should I line the sides of the chimney breast too?
Hope this makes sense. Any tips suggestions would be most welcome. Just wondering if my proposed improvement is worth doing. Would you guys do anything different? (note: external rendering is not an option btw).
TIA
BNJ
TIA
BNJ
