Quick question
S a plastering
When cutting celotex is there anything quicker than a hand saw was thinkin a electric jigsaw has anyone used this just got 120 sheets to put in a ceiling all shapes an sizes cheers
Those shitty craft knives that you extend then snap the blade of work quite well fully extended, cuts deeper through the celotex then bend it back and knife the back. I prefer to saw them but suppose if you got loads to go at these might be an alternative.
some chippys cut them with there electric saws but you need ventilation, its much neater than hand saws..
hot wire are probably the fastest. mate of mine has been hiring a cutter from ryan (1stopshop) to cut 280mm thick boards for ewi. jigsaw would probably be the cheapest option. not sure the blade depth would be enough.
ask ryan they sell the small hand held one and hire the bigger one where you sit the board on it
