Rates
Blueboyuk07
Buenos Dias fellow spreads,
Different parts of the country we all are so what rates per sq metre do you charge for
2 coat render
Skim Walls
Skim Ceilings
Render & Set
Floor Screeds
Dot & Dab
2 coat render - usually do domestics so charge between £120-£175 p/day depending on background type of finish. never worked on p/m with render
Skim Walls - anything above £2.40 above 3 metres high i like £3
Skim Ceilings - as above
Render & Set - only done domestic so same as the first question
Floor Screeds - never priced
float and set (hardwall & skim) £5.50
im in yorkshire (sheffield)
not problem giving you rates but obviousley depends on how much is required and how thick is the floor screed
2 coat render
Skim Walls
Skim Ceilings
Render & Set
Floor Screeds
i do mainly site work so its get wha your given
2 coat render = day work 120-150/day
Skim Walls = £2-3/m
Skim Ceilings = £2-3/m
Render & Set = £5-8/m
Floor Screeds = £6ish/m but never do them
